This command disables IPv4 route redistribution of the specified type into IS-IS.
| area_name | Specifies the IS-IS router process for which route redistribution is disabled. |
| ipv4 | Specifies that the configuration change is for IPv4 IS-IS routing. |
| route-type | Selects the type of export route to disable. The valid route types are: bgp, direct, e-bgp, i-bgp, ospf, ospf-extern1, ospf-extern2, ospf-inter, ospf-intra, rip, and static. |
All types are disabled.
None.
The following command disables RIP route distribution into areax:
disable isis area areax export rip
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
